Parting out 89 notch
Slo 5.0
144
St. Louis
Its time to sell my project. Ive had it for almost 6 years but Ive lost interest in it since the track closed. Most of the parts only have a few miles on them. If you want some pics of the parts pm me your phone or email I can text or email them. If you don’t like a price, make an offer and Ill see what I can do.
[email protected] located just outside st. louis, mo
89 Mustang coupe roller $2500
-Maximum Motorsports 6pt cage
-full length sub frame connectors
-BBK upper and lower control arms
-five lug conversion - new brakes
-flaming river manual rack
-QA1 front suspension
-tubular k-member
-tubular a arms with adjustable rod ends
-caster camber plates
-adjustable coil over struts with 175# springs
-new black carpet and jegs/summit black racing seats and rear seat delete
-battery relocated to trunk
-driveshaft safety loop
-05 mustang wheels (dont fit right, just for rolling)
-no hood included
* i will seperate anything on the roller *
Pro-m 3” pro tube for 42# injectors $250
FMS 42# injectors $200
Steeda fuel rails $75
Kirban fuel pressure regulator and gauge $75
MSD pro billet distributor $200
MSD coil $25
MSD digital 6 box $200
Accufab 75mm throttle body and egr spacer $200
Mickey Thompson 275/60-15 drag radials (almost brand new. Full tread) SOLD
Kirkey aluminum seat with harness and cover $150
power master 140 amp 1 wire alternator black powder coated $175
Cervinis 4” cowl hood $450
CSR electric water pump with plate and relay kit. $200
Weld Prostar wheels powder coated black(5 pass) $1200
-15x3.5 with 26x7.5 MT sportsman tires
-15x8 with 26x10.5 et street tires
Performance Automatic sfi bell $350
B&M pro stick shifter with cable $100 ($50 if you buy a tranny)
Built c4 transmission (never used) $1500
-3200 converter
- racing clutches
-Pro shift servo
-Hardened input shaft
-Pro Pump
-Deep Aluminum pan
-Reverse manual transbrake valve body
C4 trans, 3200 converter with bell for 164t f/p $300
C4 trans case $50
AEM EMS $700
-GM 3 bar map sensor
-boost control solenoid
-IAT sensor
Turbo kit for fox body $2500
-Tial 44mm wastegate
-Tial 50mm bov
-precision 67mm turbo
-ceramic coated hot side
-polished cold side
-intercooler
347 short block (5 passes) $2000
-Mexican block .030 over, o-ringed, ½” bolt holes for heads
-probe dish pistons
-scat crank
-eagle rods
-arp main and head studs
-turbo cam from comp cams
-lifters with link bar
-canton oil pan with pickup
-SFI balancer
Autometer ultralite gauges: coolant temp, oil pressure, and 5" tach $...?
Fluidyne radiator $300
proform electric water pump with back plate $100
