My recipe for built AOD..am I missing any seasoning here?
bcmbcmbcm
Jan 29, 2003
455
Here is what is goin in real soon...please let me know if I am leaving anything out:
FROM LENTECH
Lentech Street Terminator Valve Body
Lentech Rebuild Kit
Lentech fabricated aluminum pan
about $1000
FROM FORD
new Stock AOD pump
new B servo seals (yes B servo..Len says his v/b is calibrated with enough line pressure for the B servo)
$130
FROM www.ford-aod.com
Torrington thrust bearing kit
Derale cooler
$100 delivered
FROM EDGE
2600 stall converter
about $450 delivered
Other
AMSOIL ATF
Labor to remove, install, and build (great guy, I know and trust him) $1000
(Don't forget the $30 I spent on having the switch mounted :D )
Please let me know if I am leaving anything out. Don't want to skimp on a small part at this point!
Thanks!
no but i think your making a mistake on the 2600 stall speed, unless you have 4.10's
you want 3000 about.....i had a 2200 and it felt no different than stock.
and you don't seem to making crazy hp, so your actual stall speed is gonna be around 2300 w/ that 2600
