Hey,
For my senior project for hs i am rebuilding my motor for my 68 mustang. I was just looking for some input on what you guys think of my setup that i ahve planned.
holley street avenger 750 cfm carb
Edelbrock victor intake manifold 3500-8000
68 4v stock heads( I plan to Port and polish these heads)
stock 68 302 block
for cam im not to clear on this area. Either this
http://store.summitracing.com/partdetail.asp?part=CCA-31-242-3
or this
http://store.summitracing.com/partdetail.asp?part=CCA-31-246-3
I like the lumpy idle sound and i know that the overlap and lobe separation should give me that but im concerned about valve lift.
crank will msot likely be a summit forged 302 crank Im not sure about the specs but it seems affordable and good for my application. im aiming to make around 400+ horses if i can at the crank. For pistons and rods i would like to try and pump up the compression ratio. im looking for around 10-1 or something around there. my mentor says he used keith black pistons in his motor and they are nice so im thinking about those. Im not sure wheather or not to use the hypereuretic or forged pistons. I need some help selecting the exact piston as im kinda sketchy on chamber size and what not. any help with this would be extreemley helpfull especially concerning con rods. other that that i have all the small stuff worked out.
holley fuel pump and fuel preasure regulator. hv oil pump, high flow water pump and flexlite fan and all the tidbits.
Im thinking of using the stock distributor and adding a pertronix hei module to it or should i jsut junk it and buy a new distributor?
I would really like to meet my goal of 400+ horses so any help is really appreciated.
Thanks guys,
Tommy
stock 68 302 block
or this
Thanks guys,
Tommy
