My split port flow numbers
slvr2000stang
332
Chicago 'Burbs
We have preliminary flow numbers for the heads with the stock valves (1.86/1.46).
After adding the new bigger valves (1.94/1.55)we should gain a little more.
int
.100 64
.200 156
.300 189
.400 230
.500 264
.600 291
.650 310
ex
.100 52
.200 98
.300 130
.400 160
.500 190
.600 211
the heads made that much of hp difference but not trq ? still good tho...what are the heads ? I might be doing a Twin turbo to my car soon so idk if there will be different heads to better the turbo or it doesnt matter ?
On a 3.8 once you start really increasing the HP the torque does not increase as much. That is why I am having a 4.2 built.
It all depends on what you want out of it. There are no aftermarket heads just stock ones worked over. I will have the new 4.2 running by the end of this month so you will see the difference from a 3.8 to a 4.2.
