  • 1994 - 1995 Specific Tech
My timing is off..
  • Thread starter Thread starter ShiftTheDrift
  • Start date Start date May 10, 2004
ShiftTheDrift
365
Bakersfield, CA
May 10, 2004
  • May 10, 2004
Hey guys, I think my timing is off..
By reviewing my signature, can you give me some kind of an idea as to where it should be and how to set it?
Regardless of temperature, it cranks and cranks in the morning before turning over and between RPM ranges of 1000 to 2400, the engine bogs and jerks.
My mechanic worked on it a few weeks ago and advanced it after replacing a head gasket, but I'm thinking it's advanced too much. Any ideas?
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
May 10, 2004
  • May 10, 2004
14-16 is what i'm runnning (was) I had AFR 165's and E-cam
VIPERn94Five-0
3,352
Poughkeepsie, NY
May 10, 2004
  • May 10, 2004
best bet....set it back to 10* just to get it to the factory setting....if it doesnt run right there then there is something else wrong....
Anthony
C
Cobra351
131
  • May 10, 2004
Make sure the Spout was put back in. Although it would probably run real bad without it.
ShiftTheDrift
365
Bakersfield, CA
May 10, 2004
  • May 10, 2004
What is the Spout?
ShiftTheDrift
365
Bakersfield, CA
May 11, 2004
  • May 11, 2004
I'm in the process of having JMS burn a custom chip and they want to know what my base timing is..
I'm going to set it at 12 degrees. Is this reasonable?
What is this Spout I've seen mentioned in other threads? Thanks.
C
CivicEater
579
  • May 11, 2004
12 is fine, You could do more if you wanted but 12 will work. Let us know how that JMS works for you becuase I might be looking into one soon.....
ShiftTheDrift
365
Bakersfield, CA
May 11, 2004
  • May 11, 2004
will-do bud!
ShiftTheDrift
365
Bakersfield, CA
May 12, 2004
  • May 12, 2004
What is the advantage of advancing timing? ..and is it necessary to be aware of how much you advance to maintain clearance with respect to rockers and valve covers?
ShiftTheDrift
365
Bakersfield, CA
May 12, 2004
#10
  • May 12, 2004
  • #10
anybody?
mytight95
2,605
Dothan,Al
May 12, 2004
#11
  • May 12, 2004
  • #11
if you have set the timing before in the car, and you don't know what the spout is then the setting on the car is wrong. The spout is located in the passenger side fender, in the engine bay it is a little gray thing that completes the circuit for the timing advance by the computer, you remove it to set base timing, and then the computer advances it from there on.
jason
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
