I just set my timing.....I was using the wrong wire!!! I set it up to around 16 deg....its easy when you do it right, i think i picked up 50 hp!!
Setting the timing using the #5 plug wire will cause your car to run like crapGreenMustangGt said:I just set my timing.....I was using the wrong wire!!! I set it up to around 16 deg....its easy when you do it right, i think i picked up 50 hp!!![]()
jmuva44 said:I dunno, I bumped mine up from 5 to 14 (it was at 5 when I bought it) and it felt a hella lot quicker. But now it pings slightly so it needs to come down a degree or two. I know bumping up the timing can give you anywhere from 5-10 hp depending on the car.
