  • SN95 4.6L Mustang Tech
N/A cams with blower
  • Thread starter Thread starter Warrior 102
  • Start date Start date Oct 2, 2007
Warrior 102
231
Macomb MI
Oct 2, 2007
  • Oct 2, 2007
Hey guys,has anyone done this? anyone heard that someone done it? I found a dude that have a VT stage II N/A with blower and hi made pretty good power.......
Green&GoldGT
302
Virginia
Oct 2, 2007
  • Oct 2, 2007
you can use N/A cams with a blower and still make good numbers. You should check out the book building 4.6/5.4 hp on the dyno. They claim that the combos make good power but i dont have the book to tell you although they make a few runs that you can compare
hotmustang331
2,967
Bastrop,TX
Oct 2, 2007
  • Oct 2, 2007
I have VT stg 1s with my turbos and I make pretty good power. However VT stg 2 cams have ALOT of valve overlap...they will let alot of boost go straight out the exhaust. May still make more power than stock cams though. But go for it and see what she puts down
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 2, 2007
  • Oct 2, 2007
If you are going to swap cams anyways get ones that are made for forced induction. The proper valve overlap will net you better power throughout the power band. The more boost you run, the better the results will be from a proper cam profile for your build.
Warrior 102
231
Macomb MI
Oct 3, 2007
  • Oct 3, 2007
I know that proper cams gonna work better,but I already have the N/A in my car,and the dude that build my motor said that this cams gonna work ok,thy will lick some boost but make goon power.
I just want to see if anyone else have this done that's all.
by the way read this if you have a free time........
http://forums.modulardepot.com/4-6l-2v-tech/92379-vt-stage-ii-cams-blower.html
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
