  • 1994 - 1995 Specific Tech
N2O Tune
  • Thread starter Thread starter Guero
  • Start date Start date Dec 10, 2006
Guero
2,148
Dec 10, 2006
  • Dec 10, 2006
How many degrees of timing to i have to remove from the street tune, or do ihave to go off stock numbers and lower it from there? And on the tranny retard crap do i also have to bring it down? Im gonna dyno tune my car and see how it goes. If i like the hp numbers and just use it, if not i might let him squeeze more out of it.
blksn955.o
3,263
st.louis mo 314
Dec 10, 2006
  • Dec 10, 2006
For my n2o tune I kept the shift tip in retard stock (low timing), from the n/a timing I had without ping I took out 1* for every 25hp ( or 2* for 50hp), and set my commanded A/F to 11.8 instead of the 12.8 commanded n/a.
The key is to make SURE you dont have any det. at the timing you run off the bottle and go from that timing down. N2o LOVES fuel and this will make your timing alittle safer as well.
Since you "should" only be spraying at WOT and above 3k rpm or so you just HAVE to make 100% sure your commanded timing and A/F is just that...what your commanding. At WOT that really is all there is fuel and spark.
Guero
2,148
Dec 11, 2006
  • Dec 11, 2006
Thanks you also answered question i forgot to post. so 6* for a 125 shot right?
This is not for my carbut a friend wanted to know, whats the highest mph you can go up on n20?
Does Detonation shows up on the dyno, or so i've heard.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Digital Tuning Chip tuning in 2025, what are my options?
  • AnthonyA1234
  • Feb 3, 2025
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 17, 2025
AeroCoupe
