Think the univer blow through would actually be ok if calibrated to the right injector size (42lb), but that stock eec and 42lb injectors won't get along, the stock computer's fuel table and maf table are written for 19lb injectors, you can get away with 24's and 30's with tuning on the afpr but 42's are to far off and the car will run like crap. You'll need to have a chip burnt at least a dual stage 2 program one for na with 42lb injectors and one running boost and 42lb injectors. Or you can purchase a tweecer, or eec tuner, even a epec and reprogram your ford computer with the correct fuel and maf tables.
