nd some opinions
Project 77
370
Bernville PA
I've had my 95 GT for awhile now and i'm ready to drop some cash. RIght now as it sits it has the stock 302, with an X cam, 19 pound injectors, an SVO intake and that's about it. SHould I get the Trick flow package deal? I can't seem to find the part number or this anymore. Or shoud I go with a SC? I got about $5K to spend and ant to make the most of it
i'm a n/a guy. if i had 5k to spend on performance, i'd get a chp 347 stroker short block and the trick flow package.
Joes95GT said:
If you spend 200 bucks and replace the valve springs and seals, you will probably notice a world of difference. This is assuming you haven't done it already...
Joe
I haven't touched the motor in this car at all, been driving it with the X cam and stuff for about 2 years. I'm not real mechanically inclined so someone else will be doing any work for me. I'm just looking for 325-350 HP.
The stock springs are only good up to .500" lift, so putting a bigger cam in car just wears out the springs 100-times faster. You probably have very little pressure at max lift and I'd be willing to bet that the valves start floating in the upper RPMs.
Joe
