I finally have some time to start tweecing.. I Need a Flow Sheet For a Granatelli 75MM Mass Air cali. for 24lb injectors.. It's the chrome bullet version with a flange..
I have a slight feeling that it is made by Pro-M.. Because when I called Granateeli they said they were not able to calibrate it..
Am I wrong to assume that a Flow Sheet for a Pro-M 75mm bullet cali. with 24lb injectors would work..
I am kinda stopped now and a noob so any guidance would be great..
Thanks,
Rick
Thanks,
Rick
I thought about using the stock voltage range and input the ProMs number and Tweek the MAF but didn't since this one works good - but maybe one day. Oh by the way, the 1st number is the voltage and the 2nd number in () is flow rate. Peace
There You Have It
Its ALL about the PEEPS
