I went to smog that Saleen Explorer thing sitting in my garage and the computer had a couple of codes in its memory.
The car runs fine and passes all the emissions testing but fails immedately because the codes come back after being cleared. I need the assistants of anyone who has the knowledge to correct the problem. Here is what the codes read exactly from the OBD II Diagnotics sheet:
The MIL is commanded On.
Emissions-Related Powertrain DTCs, Mode 3:
Electronic Control Unit ID: 10
P0171
System too Lean (Bank 1)
P0174
System too Lean (Bank 2)
Continuously Monitored Systems DTC, Mode 7:
P0171
P0172
... First off, for those that don't remember, I removed the powerdyne POS supercharger and replaced it with a MAC CAI. I'm not sure exact what lbs of fuel pressure the injectors are but they are yellow top ford part# F4SE - A1B. The o2 sensors have already been replaced and I was told that the computer should adjust for the blower not being there. Anyone with ideas, please feel free to share. I'm trying not to go with a custom chip / dyno tune if this problem is easily solvable without that expense. Thanks for all the help
The car runs fine and passes all the emissions testing but fails immedately because the codes come back after being cleared. I need the assistants of anyone who has the knowledge to correct the problem. Here is what the codes read exactly from the OBD II Diagnotics sheet:The MIL is commanded On.
P0171
P0174
P0171
P0172
