Need a picture guys (PCV line)
5.0_GT_kid
Apr 18, 2004
1,155
Largo, Florida
Can someone post up a picture of the PCV hose that I need to take off the car to install my oil seperator? I found a line going into the lower intake, but it's smaller than the 3/8 fuel line I bought.
The line I found runs along behind the upper intake plenum and goes into a "T" fitting attached to a black plastic cylinder, is this is the PCV line?
sorry for the newbie questions guys, just want to get this done right.
That sounds right. The line that connects to the PCV valve is the one you want, no matter what.
Mine was like a rock. It went from the valve to a Tee on the driver side behind the upper.
If you put your new line on the PCV valve, it should fit tight - that is what matters. 3/8" is what I used.
Good luck.
Good luck.
Is the "T" on the driver side or passenger side? Mine is on the passenger side, runs along behind the upper intake manifold and then curves down into the driver side of the lower intake.
ya thast the right lines, you can probably remove the T and re install it so that instead of being like this T its like this |- so that the connection for the PCV is pointing to the back of the car, that way itll give you a little more room for the oil seperator
You are telling me. I thought the Tee was on the driver side (just right of center), but I must be wrong. I did access it from the driver side.
I have 18" forearms - I look like a fool trying to get those hoses installed. :D .
I should mention that in Andy's oil separator thread, he posted a lot of pics and might have some thaat help.
Good luck.
