Need a radiator that FITS. Ideas?? NOT Ready Rad.. garbage
MustangLX-5.0
856
Lehigh Acres Fla.
So I've only got so much green to spend and I NEEDED a radiator ASAP. I pick up a Ready Rad radiator at Advanced Auto, it's what they had in stock. Supposedly ok for a stock replacement. Ok, the thing doesn't fit. I double checked online and crossed reffed the numbers directly off the radiator. 433556 . yep thats the number for 5.0 stangs of this year with Auto trans and A/C. First, the radiator end supports are way too wide on drivers side.. Can't even get it to fit into rubber supports.. So I fix it so it does fit..the supports that is. Now the top bolt down supports wont fit on the drivers side.. again, too wide on radiator. and last .. when I try to put the fan shroud back in, I cannot align the shroud screws on toP without having the fan blade get jammed on the bottom. This is garbage. No way this will work ... period.
Tell me, what is a decent radiator that will FIT and not cost me an arm and a leg?
I found a rad, same size as stock but like 3 times as thick, holding onto it till I swap to a windsor, but sorry I have no idea what it came outta. I guess this peice of info is completly useless, haha, the stock replacement I got fron checkers has hold up goo though
Radiator
I've got 5 three core radiators for foxbodys if you want to take a drive to the east coast
Are they used or new? And do they fit without any modifications? And last, do they fit with stock fan shroud with clutch fan?
I was looking on LRS today. They have a Ford Racing 2 core rad for a pinch over $200. Says modification required. Any idea what kind of modification that is? It doesn't say specifically.
