need advice on 16psi set-up vortech..
stanggt00
371
baltimore md
ok guys kinda limited on money here but i want to get 16psi out of my sq-trim
this will finish me up on the motor for now anyways
i am thinking A:
8-rib kit vortech w/o crankpulley
10 % od crank pulley
2.7 8-rib blower pulley
-----------or
18% od crankpulley
electric water pump w/smaller pulley
3.12 6-rib pulley
not sure of the psi that a od crank pulley will give ....and not sure of these mods will over spin the blower but i am thinking off keeping the rpms at 6k-6.5k
Im running a 3.12 and with the intercooler im pushing 10psi. Id imagine without the intercooler it would be around 12, but yea i would definitely upgrade to an 8 rib if your wanting that much boost
:shock:so you think just a pulley swap and upping the revs could get me there with out the od crank pulley
hmmm i do see a few people here pushing there cars to 7k is that safe i mean even with heads and cams i was told keep it below 6.5k
i was thinking if i could spin the blower faster sooner i could pull out more torque on the bottom end of the rpm...(no tring to be a kb or roots) just a strong centri.
I've been running mine to 7K without issues. If you want to keep it below 6.5K then you'll obviously need to spin your blower a bit harder than what I was suggesting. Vortech has an impellor speed calculator on thier support page. That should help you see how hard you'll need to spin your blower in relation to their max speed rating.
http://www.vortechsuperchargers.com/support.php
thx for the advice guys
i think i am going to go with
10% overdrive crank pulley 8-rib
8-rib pulley kit vortech
2.75 8-rib blower pulley
that will get me to were i need for 6k redline
thxs for that calulator info. with this set up i can spin the blower alittle over rigth at 6k
