NEED ADVICE
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Mar 8, 2008
mustangfan1990
505
Lenoir, North Carolina
Mar 8, 2008
  • Mar 8, 2008
I am going to get the .275 blower pulley, but what size crank (blower ) pulley should I get to get atleast 15 lbs of boost. I know that the .275 pulley advertised 14-15 lbs on most apps, but my car has H/C/I setup so I know with that I prolly wouldnt see but maybe 12. I also need to know what my crank acces. drive pulley size is. So I need to know the crank pulley size ( for blower and acc.) and I guess I would need a smaller SC belt too. I know they make kits but I dont know the sizes that I need.
93 LX
3,081
Norwalk, CA.
Mar 9, 2008
  • Mar 9, 2008
I think if you change both pulleys at the same time you would need to go smaller on the charger and larger on the crank. Why dont you just change the one charger 1st and see what happens?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Mar 9, 2008
  • Mar 9, 2008
2.75 is a pretty small pulley and it should make 15psi just with it. but if not ASP makes 1 piece alum pullies with the crank drive and blower drive all in one pulley. they are liek 150, you can get a 7 inch blower drive or 8.
mustangfan1990
505
Mar 9, 2008
  • Mar 9, 2008
ASP is really cheap on their pullies I just checked them out. What belt size would I need if I went with a 275 and left the crank pulley size stock (6.78) or the part number?
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Mar 9, 2008
  • Mar 9, 2008
i dont know honestly the best and most accurate way to do it. is put the pulley on and wrap a string around the crank and blower pulley and measure the string. dont forget to factor in the tensioner also.
your local parts store should carry belts small enough, at least my local store did.
mustangfan1990
505
Mar 9, 2008
  • Mar 9, 2008
haha they wont carry a SC belt. Thats the belt I need
mustangfan1990
505
Mar 9, 2008
  • Mar 9, 2008
Good advice thats what I will do
Forced Induction V3 pulley change
  • JD1964
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 21, 2025
JD1964
For Sale Vortech crank and blower pulleys
  • Dontknowchit
  • Sep 25, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 15, 2025
Dontknowchit
Wheel backspacing
  • Brad Hanks
  • Sep 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2025
Brad Hanks
Forced Induction Vortech bypass valve necessity
  • 92Rustang
  • Aug 28, 2024
Fox 5.0 Mustang Tech Sep 2, 2024
Cheapskate207
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
