  • 1994 - 1995 Specific Tech
Need Brake Help!!!!
  • Thread starter Thread starter SexyStang1994
  • Start date Start date Nov 29, 2004
SexyStang1994
911
Daytona Beach, Florida
Nov 29, 2004
  • Nov 29, 2004
I hit the brakes and the pedal goes down to the floor. There is a grove in the rotor and pad, about an inch from the top of the pad that matches the rotor. We compressed the piston into the caliper, and it came back out, so I guess the master cylinder is good. Havent tried bleeding them yet.
Any ideas?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 30, 2004
  • Nov 30, 2004
Sound like there is just air in the system to me
Killercanary
The car that set the bar.
Altoona, PA
Nov 30, 2004
  • Nov 30, 2004
Jessica, have you ever replaced the fluid? How is the cap on the master cylinder? Brake fluid is hughly hydrophylic, meaning it loves to absorb water. (This is why you always here to use NEW brake fluid when doing a brake job.) When water gets in there it can cause problems and mess with the pedal effort. Typically if the pedal goes to the floor there is air in the lines somewhere. I'd bleed them first and check the pad thickness. If those check out OK, then look for a leaking brake line. If that fails they make a pressure tester for brakes that you can hook up to each caliper and test to see how much pressure it is seeing. I've never used one of these, nor do I know where to get one, but I'm sure the local auto parts store can lead you in the right direction. Let me know what you find out after bleeding them and checking the pads. You do have enough fluid in the master cylinder right?
SexyStang1994
911
Dec 1, 2004
  • Dec 1, 2004
Thanks guys! Problem solved!
Killercanary
Altoona, PA
Dec 1, 2004
  • Dec 1, 2004
What was it???
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Dec 1, 2004
  • Dec 1, 2004
Killercanary said:
What was it???
RC
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
