i have a problem i have a 2002 roush stg 1 4.6l sohc 5-speed with 4.10s, cai, off-road h pipe, spintech exhaust, and im currently also installing a 100 wet shot.
i just bought a set of new comp cams from a friend for the car i have bought new cam gears and the bee hive springs. well the cams didnt come in the box and i have no way of knowing what side is which so i called comp for some cam help and now some a**hole at comp is telling me that i will have piston to valve clearance problems and will have to have the pistons milled to fit for the valves here are the specs
comp extreme energy cams
duration 242/246
lift 550/550
is that a to agressive cam, or will it work because the guy at comp wouldnt say anything but it wont work, you have a 50% chance bye. but if you go to their site it says nothing about any clearance problems. please help if you can.
http://www.compperformancegroupstores.com/store/merchant.mvc?
duration 242/246
lift 550/550
