Need Dyno Chart For Steeda #19
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Looking for several charts that have used the Steeda #19 cam :D
If you have dynoed such a combo .....
Please ... Also include the following facts about your Stang and combo :)
year & make
short block info
heads
intake
cam
rwhp
rwtq
dyno type
dyno cal
tb size
maf size
inj size
rocker ratio
header type
mid pipe
catback
trans type
tune info
any misc combo info ... pulleys, aluminum fw, short belt, etc
Thanks!
Grady
Somethings that I found...definately interesting, since I have a Steeda 19 cam.
http://www.tmossporting.com/tabid/3517/Default.aspx
Not a SN95, but says numbers are similar to a SN95 w/ the 19 cam.
# From Bristol Dyno database, no graph though...
95 Mustang 5.0
edelbrock heads, typhoon EFI intake, 1.72 rockers, Steeda #19 cam, 73 mm MAF, 30 lb. injectors, 70 mm throttle body
263.0 HP 284.3 lb/tq
http://www.bristoldyno.com/info/database2.htm
It's the 14th 'Stang listed
All I got for now Grady.
Thank you sir :hail2:
This combo below which I got off that dyno database site reminds me of one of
our 94-95 member's combo ... White Devil.
Database Combo
heads ................. edelbrock
intake ................. typhoon
cam .................... steeda #19
rwhp ................... 263
rwtq .................... 284
dyno type ........... dynojet
dyno cal .............. ?
tb size ................ 70mm
maf size .............. 73mm
inj size ................ 30's
rocker ratio ......... 1.72
header type ........ ?
mid pipe .............. ?
catback ............... ?
trans type ........... ?
tune info ............. ?
White Devil combo
heads ................. edelbrock performer
intake ................. edelbrock rpm ported
cam .................... crane 2031
rwhp .................. 298
rwtq ................... 326
dyno type .......... dj
dyno cal ............. sae
tb size ................ 65mm
maf size ............. prom 80mm
inj size ............... 24
rocker ratio ........ ?
header type ....... bbk shorty
mid pipe ............. bbk x
catback .............. mac
trans type .......... tko
tune info ............ tweecer
We can't be certain they were using the SAME Edel heads
The Typhoon and Edel RPM are basically the same
Of course ... the cams are different
WD had his lower ported
WD had a tko which can sap 3-5 rwhp on combos at the 300rwhp range
Of course ... For all we know ... the other combo could be an aode
Anyway ... Just thought I'd share the two combos with everybody
Grady
From my understanding, and what Steeda says...
the cam has a powerband of 2300-6000.
They also say that the cam is good for superchargers.
Grady- thanks for posting up the numbers compared to White Devil's :nice:
Sure thing
btw ... I did poke around just a tiny bit on Tom's site :)
A good while back, I spent a good bit of time checking that site.
Tom has always seemed to be very knowledgeable and a good guy from the
various things he has said here :nice:
I had forgotten all the good stuff that could be found there :hail2:
Those who are considering OEM stuff could find some really good info
by spending some time there.
And for that matter ... I'd have to say the same about Thumper as well :hail2:
Both of those guys have found proven ways to obtain more with the
OEM stuff :D
Anybody else have a chart or a link to some charts with combos using
the Steeda #19 cam ???
Grady
