Need Fuel System Help. Going 347 Carb'd in 89 Fox
The Aeromotive Street Rod Pump should work just fine, I would use a -8 feed, Aeromotive carb regulator, and -6 lines to the carb, then if you want to run a return line (which I recommend) use a -6 return.
