Need Full Length Headers, HELP!!
So here is my problem, I'm running a set of headers obviously not meant to fit with a blow proof bellhousing. I bent them to make them fit and they still burn the clutch cable. Can someone please let me know who makes a set that works with a blow proof bellhousing and doesn't touch the clutch cable? Thanks a lot guys!!!!
I experienced the exact same thing - my full length headers melting my clutch cable...what I did was take one of the melted cable's mounting brackets - the bracket that mounts to the frame....spread out where it attaches to the cable and drill the mounting hole out slightly. Then, I proceeded to plant my happy arse under my car and remove one of my oil pan bolts - on the left hand side (where the offending header makes contact). Unfortunately, the angle the clutch cable ends up meeting the bell housing isn't favorable but, at least now I'm not melting cables!
Clay
