My recent purchase has some issues that I'm trying to correct. Currently I have no reverse lights and can start the car in gear without the clutch pushed in. I have been doing a lot of reading on the subject via this forum and many others; I think I have it straight even though there is a lot of confusing opinions about what the sensors actually do. I don't want to start connecting stuff and frying the electrical system. I am not very good at electrical diagrams. Also, i would like to keep the current connectors intact, if possible. I have some questions so any help would be appreciated.
Here is the current setup at the trans: I only have one connector coming out of the floorpan which has an extension on it (tiewrapped around the trans mount) with some type of terminating plug on the end of it. The Neutral Safety Sensor is hanging down and not conected to anything and there is nothing connected the reverse light sensor on the trans.
I've read that I can cut off the connector and connect 2 of the wires (PPL/ORG, BLK/PNK) to the reverse light sensor and splice the other 2 together to simulate neutral or connect to the NSS wires on the trans for the KOER diagnostic codes, is this right? Why do I only have one connector when most say there are two for a AOD car? Is it because I don't have cruise and therefore no VSS connector? If I try to find a wiring harness from a manual car, will it connect at the drivers kick panel and give me the 3 connectors that I need; VSS, reverse and NSS?
Here is under the dash: It looks like the previous owner transplanted the entire clutch pedal assembly including the connectors from another car.
I have these wires still hanging under the dash. It looks like the same connectors but the wiring colors are different and the white connector has 4 wires instead of the 3 in the previous pic. It looks like the black connector has the loopback (which has been mentioned as the Clutch Safety Switch prewired for manual with loopback by factory)
Can I get rid of the old cut connectors and use the other ones that are hanging? What is the white connector for? I can't find it in the diagrams.
hoping someone can help me out. Thanks in advance!!!
Dan
Dan
