OK, my daily driver isnt driving no more. I got a P0174 set for system lean bank 2, The car bucks and jerks at low rpms and the exhaust is way hotter on the passenger side then the drivers side. Ive tried spraying the intake but I cant find the leak, I have 9" of vacuum at idle but i do have pretty big cams, The afm n42 cams. Im also hearing like a whistle around 3000rpm, it almost sounds like a vacuum leak but could it be the accufab throttle body? Ive been pulling my hair out over this any help would be appreciated, Thanks
what could be causing the misfire?, Ive changed the plugs, the old ones had a brownish tint to them, and I checked the injectors with a noid light and also tried changing them, is there anything im missing?
