Need Help....Badly
Hyland33
10
Leicester MA
So my mustang has a lot of work done to it and i've always thought it was kind of sluggish but it didnt bother me much...until my friend gave me a ride in his 86gt with just exhaust and it pulled harder than my mustang...needless to say i havent been happy with my car since haha...
Anyways these are the parts the car has:
302 built by Ford Racing
340 HP 310 ft/lbs
GT – 40 Aluminum Heads
9.0:1 Compression Ratio
Roller Lifters
Roller Rockers
E-303 Cam
24 Pound Injectors
24 Pound Mass Air Conversion with 76 mm Air Tube
Fender Well Cold Air Intake
70 mm Throttle Body and Spacer
Polished Typhoon Intake Manifold
1 5/8 Mac Shorty Headers
Solid Motor Mounts
155 LPH Fuel Pump
MSD Coil
AOD with B&M Hammer Shifter
TCI Torque Converter with 400 RPM More Stall
2 ½ Inch Stainless Steel with 2 ½ Inch Flow Master Mufflers
The previous owner said the car had 373's in it but when my car saw the dyno there was no way it had 373's in it...
I talked to my mechanic and he said i should get some 373's. My friend said my torque converter has way too low of a stall so i should try one with a higher stall...and the car still has the sock H-pipe but i dont think it could be restricting it THAT much...
The car put down 210 horse on the dyno...which seems really low to me...
What are your opinions as far as torque converter stall and other possible issue?
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
