need help converting power doors to manual!!!
billbraskey
77
ok as title says... need help converting power doors to manual..
ive read a bunch of articles on 4 eyedpride... i made a user name to login with but still cant post:shrug: .... it all says its a strait forward swap.. but...the bolts towards the fron of the door that hold the glass? and gear and everything is diffrent ..there are two bolts one on top one on bottom... the bottom one is diffrent (the one by the speaker hole... on the 87+
ok should ahve mentioned earlier the doors i bought were off an 87+ car power windows..
my car is manual 85 gt want to keep it that way .. can anyone help has anyone done this...!? does anyone follow what im saying?
OK you have 87 power doors and 85 manual doors. To use the 87 door shells with the 85 crank and door panels, you will have to remove the power regulator (drill out the rivets) and swap in the manual regulator. They should mount in the newer door just fine. You can use rivets or short bolts and nuts. Then just mock up the manual door panel and mark the mounting holes if they are in different locations, and drill new ones. It can be done. I had a friend that put 92 door panels and power windows on his 86 GT
