Need Help fast!!!
Djstorm100
109
I have a built 302 5.0 supercharged vortech v 1 trim. anyway long story short. It was over heating in city driving so I pulled the flex a lite fans and bought a Mark 8 fan. The damn thing wont fit with my radatior that i have (fluidyne *spelling) I have no idea what to do I saw a few people that had it with their supercharger but the charger was mounted on the driver side. Not the passenger side. The crank pully is what is hitting it. Would it Be ok to make the Mark 8 Fan a pusher??
Not a good idea. With a heat maker like you have, I'd find a puller fan that fits properly/adequately. For some, a 3.8L Taurus fan is enough. Dual Spals work well for others (they are very thin). A Ramchargers/Intrepid dual fan works for some as well (it will depend upon your ambient temps, etc).
Good luck.
well i got it to fit, some what.... the radiator is sitting on the ac condenstor mounts and is flush with the top part of the front crossmember.
the only thing now is to find a way to secure both together. I have some of the plastic raditor fan "bolts' but they arent long enought I need some that are well over 4 inchs
Some folks turn the fan upside down - in case that helps you with clearance.
Dont use those through the radiator straps or bolts. It will destroy your radiator at some point. Make some brackets to attach the fan to the top and bottom of your radiator.
If you havent already, check out Monte Smith's mark VIII fan webpage - he has some info and pics.
Good luck.
got it to fit, It stays right at 185-190 but as soon as i get on it hard for about 30 seoncds it jumps to 200, i dont know if it went past it but tonight it is 84 degress. I'm kinda thinking the water pump is flowing but not flowing 100% like it should. Ideas?
as soon as I let off and go back to cruising it will drop back down to 185ish pretty quick.. also my headers are not coated. they are BBK, can this be a issue as well?
