- Jan 13, 2009
- 3
- 0
- 0
I pulled fuses while watching a multimeter on the battery... I pulled all the under hood fuses and circuit 6 (40 amp maxi fuse) got rid of the draw. In the owners manual, that circuit is the instrument cluster and PCM. Is it more likely to have a short in the dash of is my PCM bad?? Can I more isolate my draw by pulling fuses under the dash? I would just go do it but it is -2 degrees in my garage so i figured i would ask you guys first. Thanks a ton.
