need help getting power to fuel pump
Hey guy's could someone help me out here please?This is my project.I bought a 95 v6 mustang that i am putting a 6.2 escalade motor in.The v6 is out and the escalade motor is in.I left most of the factory wiring in place except for the wire's that ran to the v6 intake(sensors,throttlebody).When i hooked the battery back up after the swap all lights,starter everything else has power except the full pump.I was wondering if anyone knew the exact color wires in the factory harness that are for the full pump.
At the pump, it should be pink/blk (positive) and blk (ground).
If you need the colors and pin numbers at the CCRM, post up.
Also be sure your inertia switch didnt trip.
Good luck.
Good luck.
thanks for the reply i checked the switch(inertia)if thats the one in the hatch:shrug:going out there right now to check the harness under the hood for the pink/black hopefully i can find it and run a switched hot to it or it could be as simple as a ground we'll see
