Need help Identifing a Cam..
A67StangMaster
401
San Jose CA
well I bought this 351c block from a guy which knew nothing about it... The heads were valve ported and the springs were double springs which got me thinking mabey the cam was swaped too? well I need help finding out what the specs on this cam are...
this is what came off the cam from top to bottom.
TY79E
ISKENDERIAN
9P O8
302 351C
431 HYD
I understand the 351c and the hydralic cam but what is the other stuff?
Thanks.
Well to do it properly you need a machinists v block and a dial indicator, but you just measure the largest part of the lobe (highest lift) - the base circle (smallest part) times your rocker ratio and that should get you close. A verneir caliper works to give you ballpark numbers.
