Need help in So-Cal
Due to far too many unfortunate circumstances to list here, my 93LX5.0 is flunking the smog test required to get the registration up to date. I have already paid the fees, but the car will have to pass at a test-only center to get the registration tag for the license plate.
I took the car to a pal of mine who is a Ford Master Tech at a local dealership, and he cleaned up the mass air sensor and the throttle body, ran some injector cleaner through the fuel system, and then tested the car on their smog dyno.
After it failed, he evaluated the results and feels that the cats are no longer converting that stuff that they are supposed to convert. Long story short, I need new cats.
I currently have the BBK aftermarket H-pipe with cats that have been installed on the car since I purchased it in 1996. They are apparently beyond their service life now.
Since I am planning on selling the car, what I would like to do is buy or borrow someone's stock exhaust setup that they are likely no longer using because of switching to an aftermarket H-pipe, and use it to get the car registered, and then return it.
Anybody out there wanna help another Mustang guy in his time of need?
-Jack (in Glendale, CA)
That sucks man. I'm here in So-Cal too. However, my car is for sale, and I never even got a chance to take off the stock H-pipe. If I had a spare H-pipe lying around, I'd be more than willing to give it to you though.
You could look at the entire situation though as a reason to "test" a new H, or X pipe... you know... buy it, and "test" it. :D
I'm sure a new catted pipe would do wonders for the smog test. I'd look into that. I don't know if you're short on cash, but I always look at situations like these as reasons to legitimately put cash into my car. :D
Good luck man! :SNSign:
How to pass emissions testing:
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/det...iption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
loosen the connection at the end of the exaust manifold to the current h-pipe....it might be a little louder but it will inhale a little air into the burnt mix...dont do it too much or else it will throw a air for not enough exaust element in the mix. just give it a lil crack maybe a 1/4 inch or less, jsut enough to make it rumber but have air flow in...try that and see how it goes...might suprise you...lol
profWacko said:
Thanks for the info, JR.
As you read in my original post, I had my Ford Master Tech buddy do all of that for me already.
-jp
Post the codes on Stangnet. Often times there are people whose specific experience can help you find & fix the very thing that will keep you from passing the smog test. Because their experience is specifically Mustang, it is more focused on what it takes to get a Mustang to pass smog tests. A General mechanic may not have the collective Mustang experience of all the best of Stangnet's troubleshooters.
I don't know how things work in SoCal but in NJ I passed few years ago by puting 1 gallon of denaturated alcohol (any hardware store) into 1/4 tank of fuel. Check out the numbers.
