Need help installing rear u-joint!! ASAP
  • Thread starter Thread starter 19stang66
  • Start date Start date Jun 5, 2006
19stang66
689
  • Jun 5, 2006
Well I got the front u joint installed successfully. Now I dont remember how the rear goes back together. I got the rear u-joint attached to the driveshaft, but I need help attaching it to the rear end.
Are the snap rings used on the bearing caps that the U bolts go on? I don't see how they went back on. And none of my manuals show a good picture. Here are some pictures I took. I know its going to be easy but I just forgot how it was before. Please help!!!
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 5, 2006
  • Jun 5, 2006
No clips are used when bolting the joint to the rear end yoke. Just take them off and your U joint should fit into the yoke nicely. The joint should fit nicely between 2 small raised up areas that help to center it in the yoke.
Sometimes you have to work a little to get the U bolts into the holes.
BTW, I would have installed the grease fitting so it faced the driveshaft, not the yoke. Makes it easier to grease the joint
19stang66
689
  • Jun 5, 2006
Thanks! I shouldn't have to grease the u-joints anytime soon anyways. And when they do go bad i'll just replace them with those Spicer u-joints. I didnt find out about those until today. O well.
HistoricMustang
2,359
Confederate States of America
Jun 5, 2006
  • Jun 5, 2006
When working with U-Joints always double check to make sure all the roller bearing are in place inside the cap.
HistoricMustang
19stang66
689
  • Jun 5, 2006
I triple checked em all. How would I know if some were missing? Oh and I fixed my high speed vibration problem!
dennis112
1,561
36
79
Jun 6, 2006
  • Jun 6, 2006
Henry was offering some general advice for any U-joint replacements. Triple checking and careful assembly works well and fit within this realm.
Glad your vibration is gone--you must have been overdue on the U-joints.
Good Luck!!!!!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
