I've noticed a whine recently coming from my transmission that increases in pitch as speed increases. Most noticeable in 3rd. 4th and OD. Probably because it is at a higher pitch than "road noise" at that point.
I can manipulate (but not eliminate) the sound by placing my hand on the shifter and pushing it firm against the stops or the sides of the plate. What I was wondering is if it is just housing to shifter vibrations, or is it something more serious?
I figured I would start the elimination process by re-doing the seal between the transmission housing and the shifter. Although I recently did this in the past 4 months. So now I'm trying to locate a fitted gasket this time instead of putting down a bead of RTV. I just can't seem to find one. I need one for a '03 GT 5-speed Tremec 3650 and a steeda tri-ax.
Thanks,
Jinx
Thanks,
Jinx
