- Apr 30, 2005
- 58
- 0
- 0
ok, I swear my car hates me. I just recently figured out the issue I was having after my 3g install and now this. I went out this morning and started the car. it was just fine. I don't really think this is related but I'll post it just in case. I did a little seafoam in the BB line and ended up stalling it. I restarted the car after a tad of cranking(just as I did when I did my truck) and it was fine. I finished adding the seafoam bit by bit and I never stalled it again. after I was finished I shut it off and waited 15min. when I went back out to start the car it acted like I had a dead battery. when I put the clutch in and turned it over it had that dead batt. slow crank until nothing(about 3-4 cranks). I ended up tossing my batt. charger on it with a 200Amp start. it still did the same thing. the dash gauge would show like it did before until I started cranking then everything went dim or dead. I then started moving the clutch pedal up and down a bit and I noticed the cranking got stronger/weaker if I hit just the right spot. I kept the key forward and still cranking and I guess I hit just the right spot as the car started. a few blips on the gas(due to the seafoam) and all was fine. it ran pretty smooth and everything. I let it run for around 10min. and shut it off. when I tried to restart it the same thing happened again, it wouldn't start.
does this sound like a clutch cable problem here since it did start while I was moving the pedal up/down a bit when it started? could it be the solenoid? battery? seafoam?
I tested the volts on the battery before I did the seafoam to test my 3g(I finally found my meter) and it was showing around 14.2V at idle.
right now I'm almost wishing that I never did the 3g upgrade since after I did that it has been one issue after another.
I correct the connections at the solenoid so the car will start and for some strange reason I start to get a rough idle afterwards. I'm told to run some seafoam through it and now this.
EDIT: I just thought I should add that the batt. charger was still connected when I finally got the car to start the first time. when I tried after I shut it off the charger was no longer on the car. that's why I asked about the battery as well.
