I want to make more hp and I know the lower block wont take it. i.e. SC
My question is which of the 3 sizes of short block will work best with my AFR 165 heads and Eldebrock Performer intake ? See sig. for more details.
My 94 GT has ~128k miles on it. Put down 281/308 with timing set 10*and an o/r Pro Chamber. I took that off and put bassani o/r x-pipe back on and bumped timing to 12* It really pulls better now, and thats with the stock cam and 24lb injectors.
So, the best option I can come up with is a CHP Pro Street short block. They advertise the 306ci for 2499.99 - the 331ci for 2599.99 and the 347ci for 2599.99. I figure I can use everything from the heads up.
I do plan to upgrade to an 80mm MAF / 70mm TB and a Ed Curtis Cam.
Thanks in advance your help. Dewman
