Need Help PLEASE
GreatWhite
232
Fairfield, PA
I misplaced the key socket for my lock nuts for my wheels. I've looked everywhere for them and can't find 'em. Anyone know a way to get them off?
Also, I need to drop the gas tank soon for my battery relocation. Is that a real tough job?
Thanks.
Wheel locks. I have used an air hammer to get the lugs off, when I don't have a key. I have much experience with that tool. Just be careful to not screw up your wheels.
Gas tank. The gas tank is easy to remove. Make sure you have less than a quarter tank. Then diconnect the fuel lines, and the electrical connection first. Then unbolt the neck from the tank. After that, just unbolt the two gas tank straps, and let her drop. (A second guy and a floor jack or two, are priceless.):flag:
That sucks for me because I don't have air tools.
And I also have almost a full tank of gas while the car isn't running. I'm relocating my battery and have to drop the tank just a little to get clearance to drill holes for my battery box.
if all else fails, pound a socket over the lug and remove. or use a metal chisel and cut it off. More than likely you will need to change the stud with the lock on it if you chisel it off. (unless you are a surgeon or something.)
