  • 1994 - 1995 Specific Tech
Need help quick : Installing fuel pump !
  • Thread starter Thread starter Stangfreak95
  • Start date Start date Apr 8, 2005
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Apr 8, 2005
  • Apr 8, 2005
I'm installing my 255lph fuel pump and I'm stucked at disconnecting the fuel lines. I have fittings but they dont seem to work. Can anybody explain that procedure... Or post pics of what I need to remove the damn fuel lines.
Thanks
94gts
873
Carmel, New York
Apr 8, 2005
  • Apr 8, 2005
push the line in(more onto the fitting). then push the disconnect tool in the outer opening of the line while holding the line in place(still pushed forward) hope this helps, kyle
RIO5.0
6,892
N.H.
Apr 8, 2005
  • Apr 8, 2005
I found the tank lines to be a mofo compared to the connections at the motor...I had the disconnect tools to...the smaller line gave me a run for my money...I ended up taking a 2 small screwdrivers and sending it up the line some....look in there and you can see the 2 small metal tabs that are pushing down holding the line in place...get under them and lift a tad and it'll slide right off...
Stangfreak95
add a 4
3,571
Apr 8, 2005
  • Apr 8, 2005
ok thanks. Good to know that it's not only me that had trouble with those 2. I will try with the 2 screwdrivers if I dont get it soon.
RIO5.0
6,892
N.H.
Apr 8, 2005
  • Apr 8, 2005
I have all these tools...like i said...the little one was a drag....do you have one of the small pick sets?? they have like 4 in the kit with 90 deg bends, a straight one etc?? they work sweet to snake in there to get under the little tangs...Good luck...Pisser ain't they...
mystang94gt
951
Bay Area, CA
Apr 8, 2005
  • Apr 8, 2005
I have the tools like the ones pictured (green and yellow ones) but they didnt work for ****. I ended up using the two screw driver method as well when I sawpped to my 190 lph. good luck
RIO5.0
6,892
N.H.
Apr 8, 2005
  • Apr 8, 2005
I believe the Green/Yellow are mostly for the 2 intake line sizes...one of those on the tank is a small one and neither of the above will get inside it to release it...the tank lines have tangs pressing down...the motor one are different for sure...
Stangfreak95
add a 4
3,571
Apr 8, 2005
  • Apr 8, 2005
Ah finally did it with the tools on the right. My friend the mechanic stopped by and we did it together. He said they were really ceased or so. I was pulling on the line while he was messing with the clip.
Thanks guys
RIO5.0
6,892
N.H.
Apr 8, 2005
  • Apr 8, 2005
Slick...glad it worked out...i can honestly remember that line being the worst part on my 190 install..
Stangfreak95
add a 4
3,571
Apr 8, 2005
#10
  • Apr 8, 2005
  • #10
Yes I've been done for about an hour and an half now. Everything is re-assembled. I didnt have trouble at all putting the filler neck back into place. Really it was only those 2 gas lines that gave me trouble.. I didnt even start the car to see if it works or not. I'll do it tomorrow.
Tomorrow I'm going to install my HPM driveshaft loop, if everything goes to plan
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
