  • SN95 4.6L Mustang Tech
Need Help Quick!!! Steeda Tri-as install
  • Thread starter Thread starter fellamansteve
  • Start date Start date Jul 27, 2004
F
fellamansteve
108
Seattle
Jul 27, 2004
  • Jul 27, 2004
I'm supposed to put some silicon gasket maker on the new shifter before I put it on the tranny...what constitutes as silicon gasket maker and where can I buy some if my dad doesn't have some in the basement? Thanks!
percman
12
  • Jul 27, 2004
You can pick it up at your local auto parts store... ie autozone, checker... Its RTV silicone gasket maker. I got the blue stuff which has worked fine for me. Just make sure you clean of the existing sealant first to make sure you will get the best possible seal. A razor blade is probably your best bet. Just be careful not to nic the metal.
http://www.bullittarchive.com/Mods/Shifter/
twogts4us
4,188
12
79
Dunedin, FL
Jul 28, 2004
  • Jul 28, 2004
Agreed with all the above, except I'd recommend RED RTV...high temp. Blue is typically only good up to 400 degrees, whereas Red is good to 650. Blue is probably fine, but to be safe, I used the red.
And here's a little additional useless info for ya, for free: RTV stands for "Room Temperature Vulcanizing".
Best of Luck!!!
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Jul 28, 2004
  • Jul 28, 2004
Here's another "how-to" guide for an aftermarket shifter, thanks to fnsweet:
http://www.fnsweet.com/garage/shifter/index.shtml
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
