Need help setting initial timing
  • Thread starter Thread starter Roxy89
  • Start date Start date Mar 8, 2007
Roxy89
38
  • Mar 8, 2007
Ok so I am a little new to setting the timing on the mustang. I do a lot of mechanical stuff myself, but have yet to use a timing light. This is a first for me so I have a question. I have already set the 1st piston to TDC on the compression stroke, and the balancer was at 0 deg. right on that little pointer, now my question is this. When I clean up my balancer and mark the timing points, how is it that I check the timing. If I understand correctly, when the strobe light of the timing gun flashes it makes the marks look like they stay still. So am I supposed to turn the distributor until the mark I want (for example - 14 deg) is lined up at the pointer steadily with the flashes of the timing gun? If this is correct, please let me know so I may continue to set my timing. If not please let me know what I have to do. Thanks.
Aryan15
236
CA
Mar 8, 2007
  • Mar 8, 2007
sounds right, but make sure to disconnect the spout connector before turning the distributor. Also make sure there are no loads such as a/c or electrical loads.
HISSIN50
34
129
Mar 8, 2007
  • Mar 8, 2007
In case it helps, here's some info.
I use a silver sharpie to color in the 10 and 14* lines (for instance). The timing light strobe picks up the silver ink easily.
Good luck.
Y
Yellowpnoy
203
  • Mar 8, 2007
Someone gave me a great pointer, if you dont want to start the car, just pull the fuel pump relay (under the drivers seat), so that the motor wont start and you can set the timing that way!
Anthony
Roxy89
38
  • Mar 9, 2007
Ok so I was setting the timing and test driving every once in awhile and I couldn't get it to ping. Right now I have it at 20 degrees and no pinging. It didn't ping until I took it to about 30 deg but then it also gave me idling problems. But at 20 deg it is not pinging and running very smooth. Does this sound normal? I took the spout connector out with the car on and then hooked up my timing light and turned the car on and then read the timing. Now when I finish setting the timing and tightening the distributor, do i just connect the spout connector again with the car on and then take it for a test drive, or am I supposed to shut it off again, then put the spout connector and then test drive it? Please let me know because to me, 20 deg is too much. Also, the deg reading is at the end of the pointer correct? For example if I am standing in front of the car looking at the engine and look down I see the timing pointer. Am I supposed to line up the timing marks all the way to the right of the timing pointer?
Modular2v
3,222
23
99
oklahoma
Mar 14, 2007
  • Mar 14, 2007
20 degrees might not be too much....it really just depends on the car. What octane fuel are you running, premium fuel fights off pinging when timing is aggresively advanced
Roxy89
38
  • Mar 14, 2007
Well I was running premium fuel, but my last tank I put in regular 87 octane just to see what it would do. I figured if it pinged a little I would back it down to maybe the original 14 I was shooting for and could do fine without even using premium fuel. Well to my amazement, I have been on that tank of gas for about 3 days now, and still nothing abnormal.
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
