SLiM JiM 156
Yea the only time you will get codes is if the CHECK ENGINE light is on. I still think it is a vacuum leak too but it is hard to trace that crap sometimes. My experience with the IAC and the loose hose was the car would run as long as I had my foot on the gas and kept it revved. I was even able to drive but had to keep restarting it at stops. It would finally go away after a few minutes and run fine. Well not with the loose hose...I had to reconnect that to fix it. Try picking up a Haynes manuel and see if there are some ideas there. About 15 bucks from Autozone or similar. I did a rear bearing change with mine and it described the process pretty well.KDub said:I tried it with no luck. The check engine light is not on and hasn't been.
All I should have to do to retrieve those codes is hook up and hit the link with my scanner, but I get nothing...
Zorro said:Does it still die? If not is seems as it may be an intermiitent concern. I am here in Bellflower, California I don't know how away we are but I am a ford tech. I'd be happy to help you out if you are in the area if not well get those codes read.
SLiM JiM 156 said:how old are your o2's?
coramprat said:Yea the only time you will get codes is if the CHECK ENGINE light is on. I still think it is a vacuum leak too but it is hard to trace that crap sometimes. My experience with the IAC and the loose hose was the car would run as long as I had my foot on the gas and kept it revved. I was even able to drive but had to keep restarting it at stops. It would finally go away after a few minutes and run fine. Well not with the loose hose...I had to reconnect that to fix it. Try picking up a Haynes manuel and see if there are some ideas there. About 15 bucks from Autozone or similar. I did a rear bearing change with mine and it described the process pretty well.
TripleBlk said:You are not going to see a code for a bad IAC . You tried two used IACs. They last MAYBE 50k miles. Time you tried a new IAC, sorry. Cleaning won't work 100% of the time , either. Don't ask me how I know !!
JB9789 said:The theft light should flash when the ignition is switched on and stay flashing if it is the transponder ring or your antitheft sys do you have an after market alarm?
you say you got the car about 2K miles ago i would call who ever you bought
the car from and ask them if they had any problems or anything done to the car
do you have a chip in your car? and did you check all your fuses?
I"m agreeing with you man I think that this is the problem!osustangfan said:my 97 cobra did that. i had to change out the ignition because a wire of something came loose. part of the sensor that reads the chip in the key? but it did EXACTLY what youre explaining.
