Need Help/suggestions
Fox89jeepjk13
Hi I have a 89 mustang Gt convertible that's has high miles but drives well and is extremely fast. A while ago i was driving it and i went to shift it into 2nd gear from 1st and it made a clunk noise and started to rev without me going anywhere like as if i was in neutral. Do you have any suggestions as to what i could check to fix it? It is a manuel trans and i am very mechanically inclined. I have never done any transmission work in the past so some suggestions as to what it could be and what i could do would be great.
Thanks
Other info
If you physically put the shifter in 2nd, and it revs as if it's in nuetral, then likely there is a mechanical issue inside the t5.
Can't say for sure what happened until you open it and look, but I'm gonna say you sheared the teeth off 2nd gear
