Need help with '02 throttle connections
Ardent
11
Hello first off, new to the forum, I have an '02 GT and it will idle nicely but soon as you hit the throttle at all it will sputter and stall. The plastic cable to the throttle body butterfly is awefully loose in its sleeve, seems broken or disconnected. What is the second, lower, plastic cored push/pull cable? Assuming it's a throttle pick up/advance of some sort, though not sure as to what it leads. Advice in general appreciated. For the record the MAFS and throttle body are fine.
