Need Help With 1966 Mustang Heater Problem
NEPAFM
PA
Hello,
I need some opinions on what the heck has been holding up my Mustang rebuild project for the last three weeks. I recently installed a new heater box, resisistor, and heater motor into my 1966. For some reason, as soon as I turn on the ignition the fan motor kicks on and will not shut off. I can move the three speed switch in any direction and it doesn’t stop running. I tried to unplug the resistor and it still runs. If I unplug the brown wire heading into the heater motor, it stops running. Any help is greatly appreciated!
thank you!
  • Sponsors(?)
Billm
47
Time to get a wiring diagram and start tracing your wiring and find why or where the brown wire is hot.
Olivethefet
Slap me as well as point and laugh
May 17, 2018
1,605
1,022
123
39
Enterprise AL
Yeah, you've definitely got something wired wrong. Do you have a wiring diagram as suggested? The system isn't that complicated. Pictures of how it is currently wired up might help as well.
NEPAFM
PA
I did purchase a 1966 shop manual, which includes a diagram. If the fan has power all the time there’s no reason it would be the ignition switch or heater control switch right?
NEPAFM
PA
All the wires are correctly hooked up that’s what is so frustrating. Red wire from battery to solenoid, black yellow from solenoid to fuse block, yellow to back of ignition switch, black green from ignition switch to fuse box, brown to heater motor. The only things that arent new in the whole loop is the ignition switch and wires from heater control to resistor. It makes me think one of those two are bad but it’s probably the wires themselves somewhere.
Billm
47
It sounds like the heater motor has constant power. It might be from the constant power terminal on the ignition switch post or the fuse block. Check the diagram and find the blower motor wire coming into the car thru the firewall Andy see where it goes under the dash.
Zeeks Stang65
Maryland
Not to steal the thread but I have a 65 and I am having trouble getting heater core out. AIready opened up heater box and removed front but core doesnt want to come loose. Any help is appreciated. Thanks
NEPAFM
PA
So I had an extra wiring harness when I bought the car. I replaced the old harness with the new harness. ITS STILL NOT WORKING. Do you think it could be the ignition switch? The fuse block was replaced with the new harness.
Thread starter Similar threads Forum Replies Date
A Engine Need Help Finding a Part Classic Mustang Specific Tech 1
M Progress Thread 1966 6 cylinder clutch problems. Need help 1965 - 1973 Classic Mustangs -General/Talk- 1
Project_66 Need Help With This One! 1966 Mustang 1965 - 1973 Classic Mustangs -General/Talk- 4
mustangjunky help needed for a 1966 ford mustang sprint 200 strait 6 The Welcome Wagon 2
V 1966 pass side stop lamp not working..help with wiring needed Classic Mustang Specific Tech 3
M 1966 Mustang AM radio help needed 1965 - 1973 Classic Mustangs -General/Talk- 1
O 1966 straight six need help Classic Mustang Specific Tech 1
J Need Help with 1966 289 that won't crank just click Classic Mustang Specific Tech 5
Lst1stndng Need help/advice on running fuel injection wiring in my 1966 coupe Classic Mustang Specific Tech 8
lamrith New MSPnP2 in 94 Mustang, need help getting stable idle once warmed up. Digital Self-tuning Forum 0
W 347 Header Size and exhaust Diameter 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Z I need help with pistons 1996 - 2004 SN95 Mustang -General/Talk- 1
trlps_ Need help, car wont rev up or drive 1996 - 2004 SN95 Mustang -General/Talk- 2
T Electrical Need help with A/C clutch cycling connector Fox 5.0 Mustang Tech 2
bmgstang Need help with tune high idle Digital Self-tuning Forum 3
S Engine Need help: heater hose routing for 92 2.3 liter 2.3L (N/A & Turbo) Tech 4
T First fox... she needs help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
C Engine Help diagnosing a whine at low gas pedal pressures - 1998gt SN95 4.6L Mustang Tech 0
Kylor Need help pricing 2000 Roush Stage 2 What is it Worth?!?!? 12
0 Need Help Transmission Swap 2005 - 2009 Specific Tech 1
Cheapskate207 Brakes Need help with Brake ID Fox 5.0 Mustang Tech 12
Wayne Waldrep Engine Trouble with the old pile...I mean car. Need some help. Fox 5.0 Mustang Tech 7
YadiStang Need help with my 1969 oil dipstick 1965 - 1973 Classic Mustangs -General/Talk- 8
D 1995 mustang gt 5.0 Need help please! 1994 - 1995 Specific Tech 8
M Need help tuning megasquirt with kenne bell supercharger Digital Self-tuning Forum 5
D Fox Need help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
1 Engine NEED HELP PLEASE!! Fox 5.0 Mustang Tech 4
atey950 89 5.0, Trick flow stage 1 h/c/i, Megasquirt pnp novice needs help Digital Self-tuning Forum 4
Silver Bullitt Desperately need electrical help! 2005 - 2014 Specific V6 Tech 10
Jetzv8 2015 mustang led license plate wiring help needed 2015+ (S550) Mustang -General/Talk 0
wbrockstar Help Needed To Identify Wiring Component On Hanger At Fuel Pump 1994 - 1995 Specific Tech 0
M Engine Need help on belt with V3 Fox 5.0 Mustang Tech 4
O Need help..ASAP! 1996 - 2004 SN95 Mustang -General/Talk- 2
ShadowBlueGT Electrical OEM stereo reinstall wiring help needed! Fox 5.0 Mustang Tech 2
ChuckFoxLx Engine Need help and tips Fox 5.0 Mustang Tech 9
L I'm New, Need help. please. SN95 V6 Mustang Tech 1
T Need Help With Wiring Fox 5.0 Mustang Tech 2
Blueharry Need Help picking a New springs and shock! 1996 - 2004 SN95 Mustang -General/Talk- 0
5 NEED ADVICE FROM COMMUNITY MEMBERS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
R 2013 Mustang GT pad and rotor change, need help. 2005 - 2014 S-197 Mustang -General/Talk- 4
Keionte HI, All Need Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 112
Conformist Installing '98 Mustang v6 Fog lights (Help needed) 1996 - 2004 SN95 Mustang -General/Talk- 3
D Need Help with wiring an 87 GT Convertible Radio Fox 5.0 Mustang Tech 30
C 2000 shell but insides are all 1995 gt....need help 1994 - 1995 Specific Tech 4
0 Hey guys, 01 gt having problems really need some help. SN95 4.6L Mustang Tech 8
P Help..need on changing tranny dipstick. SN95 V6 Mustang Tech 0
M Pimpxs or Terminator x...need help making a choice Digital Self-tuning Forum 18
mustangpauly 90 mustang mspnp2 need help with startup. Digital Self-tuning Forum 8
M Fox 85 GT Need Help identifying wires. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
R Progress Thread Help! Need help figuring out where an electrical component goes in the harness and what is it? 1996 - 2004 SN95 Mustang -General/Talk- 2
