  • SN95 4.6L Mustang Tech
Need help with a DTC code.
  • Thread starter Thread starter TrippiGT
  • Start date Start date Aug 20, 2008
T
TrippiGT
22
  • Aug 20, 2008
I've got a 99 GT and after my car got pretty wet from a huge storm the other day I've been getting a code.
""P1152" Lack of H02S21 Switches-Sensor Indicates Rich (see P2198)"
Has anyone ever seen this before, or maybe know what could be causing it? I'm thinking I may have gotten a sensor wet and it crapped out or something, but I don't know where to start looking. Any help would be great.
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Aug 20, 2008
  • Aug 20, 2008
gonna have to monitor PIDS. might have a leaky injector
F
faststang_728
558
Greenbrier, WV
Aug 21, 2008
  • Aug 21, 2008
it could just be the sensor as well. The heater circuit could be shorted to the signal circuit causing it to have 5v on it. The ecu reads that as 1.66v and thinks that it is a rich condition. Check the red and light green wire with a DMM for voltage with the key on. It should be less than a volt.
blackink00
Mar 30, 2005
545
Tempe, AZ
Aug 21, 2008
  • Aug 21, 2008
the o2 only goes to 1 volt max tho. but yeah most likely its just a sensor. i do those more then anything with that code.
F
faststang_728
558
Greenbrier, WV
Aug 22, 2008
  • Aug 22, 2008
If its shorted to 12v through the heater ckt though the pcm will read 1.66v on the 02 PID. thats how you can tell its shorted to power cause the sensor itself only makes 1v not 1.66v
T
TrippiGT
22
  • Aug 22, 2008
I logged some PID's with my Diablo programmer. O2S11 started at 0 V and slowly went up to 0.10 sitting at idle. O2S21 stayed at 1.67 V the whole time. Does that mean its bad? And which on is which? Is O2S21 the driver side or passenger side?
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
