Need help with a PROBLEM
  • Thread starter Thread starter Craig Richardso
  • Start date Start date Jun 4, 2009
C
Craig Richardso
Williamsburg Va
Jun 4, 2009
  • Jun 4, 2009
Hey yall
I need your help with a problem. Ok to start i have a 66 mustang coupe that i have converted into a shelby clone. I have installed a mustang ll front suspension. I have built and installed a 1969 351W between the fenders. I just installed the 67 style Shelby hood for the 65-66 model. On the motor i have installed a edelbrock RPM intake that is regular height, no spacer. and topped it with a holly 750 vac sec w/ electric choke. And heres my problem, I have no room for a air cleaner to fit. i only have 2 inches of room at the most. Has anyone else here had this problem? Does anyone know of a drop base that will clear a vac sec system, neither proform or K&N fit, already tried. CUTTING a hole in the hood is not an option.
Thanks for your help ahead of time.
Craig
H
htwheelz67
444
mission viejo ca.
Jun 4, 2009
  • Jun 4, 2009
try a 14" 2"drop base air cleaner, I have heard that the must 2 setup raises the engine a bit.
zookeeper
3,415
63
109
Rogue River, Oregon
Jun 5, 2009
  • Jun 5, 2009
Although they are expensive, the air cleaner from a 1969 Corvette with a 390-horse 427 is absolutely the lowest air cleaner you can find. It clears a vacuum secondary Holley just fine, and looks like any other generic 14" air cleaner. The base is so low, it nearly swallows the carb, so if the carb will fit under the hood, chances are the carb with the 'vette air cleaner will as well. Like I said they reproduce them, but expect to pay near $200 for an accurate one. I got the one for my wife's Corvette from Dr Rebuild, let me know if you're serious and I'll find the phone number. I just did a quick search and found this, good luck! http://www.docrebuild.com/
HookandLadder
261
St Louis
Jun 6, 2009
  • Jun 6, 2009
Moroso drop base should work. Just use the base and then a 3" K&N. You can also add the new K&N top flow lid for better air flow.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 7, 2009
  • Jun 7, 2009
Doc Rebuild (aka Geoffrey Coenen) is an excellent outfit, I have spoken to him personally, although he is now semi-retired, last I heard. The Corvette part is no doubt excellent, if he is selling it. The aftermarket part is probably cheaper, and looks it, with a huge stamped "MOROSO" logo on it. That doesn't bother some people, but it would bother me.
zookeeper
3,415
63
109
Rogue River, Oregon
Jun 7, 2009
  • Jun 7, 2009
I know it's hard to believe, but the Moroso base is a full inch taller than the stock Corvette part. My wife's car had a Moroso drop base air cleaner when she bought it, and had to use a very thin air cleaner in order to clear the hood.
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
Mustang II V6 conversion to V8 HO and T5 problems and solutions
  • greenflash79
  • Jul 6, 2025
  • 2 3
2K
1974 - 1978 Mustang II Talk & Tech Monday at 11:43 PM
greenflash79
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
