In a attempt to reduce the amount of wires under the dash that were going to nothing, i seem to have cut off the wire going to my brake pedal sensor.
( before you get crazy, i had half a garbage can of wires from old stereo's alarm systems, amps,graphic equalizers, ect that was either under the carpet or the dash. it was bad.)Now, since my turn signal switch, on the collum, is also not happy i would like to by pass everything.
So, if i run a 12v hot to the one side of the peddal sensor, what wire could i tie into on the main harness switch to light up the brake lights? If you could give me location and color, that would be great. 1965 289 coupe.
i plan on doing a painless setup probably this year, but it would be nice, especailly for those following me, to have brake lights..
Thanks
Thanks
