NEED help with car stalling and missfiring
The car is a 89 with world products senior heads/edelbrock intake/F cam/S trim. Has a chip with a base tune on it, the car seems to idle fine and drives fine when its cold. When it gets up to temp around 2,000 rpm it feels like its misfiring or something of the sort, shakes the whole car and can BARELY turn any more rpm but if I can limp it up to 3200 or so and sometimes it clears up and drives normal. If I push in the clutch during all of this I can rev it up and its fine. When Iam coming to a stop the car will slowly come down in the RPM like normal but when it gets to about 1000 it drops and dies unless I feather the throttle. When I go to crank it over after afew times stalling the battery seems nearly dead and will just BARELY start the car. Just had the battery tested and it checked out fine. The battery is in the trunk with 1 gauge cable and the negative runs all the way up to the block then I bolted it to the sway bar bracket(removed paint from underside). When I go to crank over the car when I first try to drive it, it cranks over great BUT I have to feather the throttle to get it to start. Any ideas? Iam guessing its afew problems thats causing this to happen.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
index.php
index.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Dumped the codes and got 21-Engine Coolant Temperature (ECT) sensor out of range - ECT and code 24- Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range - IAT VAT. Iam going to replace these sensors either way but does it sound like this will solve my problems?
Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor.
Note that that if the outside air temp is below 50 degrees F that the test for the
ECT can be in error.
The ECT sensor has absolutely nothing to do with the temperature gauge. They are
different animals. The ECT sensor is normally located it the RH front of the engine in
the water feed tubes for the heater.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate
readings.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is
a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower
intake manifold, the voltage readings will be lower because of the heat transfer.
Voltages may be measured across the ECT/ACT by probing the connector from
the rear. A pair of safety pins may be helpful in doing this. Use care in doing it
so that you don't damage the wiring or connector.
Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Ohms measures at the computer with the computer disconnected, or at the sensor
with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
Code 24 - Intake Air Temperature (ACT) sensor out of range. Bad sensor, bad wiring. The ACT for
Mustangs built before 95 is in the #5 intake runner. It measures the air temperature in the intake to
help computer the proper air/fuel ratio.
Note that that if the outside air temp is below 50 degrees F that the test for the ACT can be in error.
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is a good number if
the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage
readings will be lower because of the heat transfer. Here's the table :
194 degrees F = .61
Note that all resistance tests must be done with power off. Measuring resistance with a circuit
Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor
disconnected.
The car was inside where it was atleast 50 degrees more around 60. It did the missing last year and I never figured it out. But does it seem like the codes that it pulled could be what is causing my problem? Like I said I will be replacing them anyways just to be safe. Thanks for the help.
Well I replaced those sensors and theres no more stalling and it didnt miss for about 25 minutes of driving then all the sudden about 2 miles from home it started doing it again so I babied it home. It was late so I didnt pull the plugs or anything yet, I will do that after work and come back with the results.
