Need help with EEC4 code
  • Thread starter Thread starter rd
  • Start date Start date Jun 13, 2006
rd
3,316
63
109
Ocean Springs MS
Jun 13, 2006
  • Jun 13, 2006
A friends 89 F150 with a 5.0 and an aod, quit running well this pm. It starts reluctantly and drove home slowly, and is running kind of rich idling in his yard.
I pulled the codes and got a KOEO code 98 EPC and FMEM in effect. I think that's limp home mode.
Also got a code 63 for TPS voltage below minimum. This one I understand.
The 98 is for electonic pressure control, driver failure, and I cannot find any reference as to what that is. My books describe it in the code list, but I can't figure out what sensor/actuator it concerns.
Any suggestions?
Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 13, 2006
  • Jun 13, 2006
Code 98 - basic computer internal tests not passed before it started processing the request to dump codes. Do a Key On Engine Off test before starting the engine. Wait until you see the 11 flash before pressing any buttons if you have a hand operated scanner. The computer is operating in Limp mode, so fix any codes it dumps prior to doing anything else.
Code 63 - Throttle Position Sensor (TPS) signal too low TPS . TPS out of adjustment, or 5 V VREF missing, broken wiring or bad connections.
Try this... Currently there is some dispute about setting it at .99 volts being worth the effort, but anything less is probably OK. All you need is less than 1.0 volt at idle and more than 4.25 at Wide Open Throttle (WOT). You'll need a Digital Voltmeter (DVM) to do the job.
Wire colors & functions:
Orange/white = 5 volt VREF from the computer
Dark Green/lt green = TPS output to computer
Black/white = Signal ground from computer
Always use the Dark Green/lt green & Black/white wires to set the TPS base voltage.
Use the Orange/white & Black white wires to verify the TPS has the correct 5 volts source from the computer.
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks. Set it at .97v-.99v, the closer to .99v the better.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn. Then you adjust the TPS voltage to .98v, reset the computer. Start it up, if the idle is to low then turn the screw in until it is just right, then readjust the TPS voltage to .98v and reset the computer and start it up. The key is to adjust the TPS voltage and reset the computer whenever the idle screw is changed.
rd
3,316
63
109
Ocean Springs MS
Jun 13, 2006
  • Jun 13, 2006
Thanks. It makes more sense now. He's going to the local 5.0 builders shop to get it fixed, if it will get there.
I am out of town the rest of the week.
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
D
P0010, P0020, P0102, P0135, P0155, P0443, P0446, P2008 Error Codes - Help Needed (Electrical)
  • dkachal
  • Jul 24, 2023
2K
2005 - 2014 S-197 Mustang -General/Talk- Feb 23, 2024
milky_toast
M
M
HELP! 06 mustang roush 4.6l v8 stage 2. Throwing a wrench
  • mustangmike88
  • May 24, 2023
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 24, 2023
mustangmike88
M
