Need help with Intake Decision
gcwh02
515
pottstown, PA
Ok, here is the combo... I have decently ported and milled windsor jr heads, 350 stroker (302 block), 12:1 compression, and a lunati cam. I bought it as a long block. I was told that that long block went a 11.8 in a 86 vert with a holley 750 and edelbrock intake(not sure which one). My question is, should I go with the TFS Track or the TFS box R.
Just go with a trick flow r-series manifold. Same dimensions port wise as the box r. The only difference is the box r is taller. So you may need a cowl hood with it. But it doesn't look like you need one with the r-series manifold. And you could get it with either the 75mm or 90mm throttle body.
