need help with maf selection!!!
  • Thread starter Thread starter project67
  • Start date Start date Dec 8, 2009
P
project67
116
  • Dec 8, 2009
ok i got my 331 stroker alive and running. i need to find a suitable maf for this combo. the car came with a "cobra" maf according to the previous owner. i have no real way of substantiating this. all i do know is the housing measures 70mm but i cant find any numbers on it. the maf sensor and housing are marked across them w/paint pen like they came off of the same car together (prob junkyard stuff) the numbers on the sensor are this:
f4sf-12b579-aa
afh70-02a
so here is my question-is there any way of knowing if the housing is for 19 or 24lb injectors? and if it is for 24lb, what would be a good sensor for this (my current sensor failed today)? if the housing is for 19lb'ers what is a good housing/sensor combo for this w/out breaking the bank?
thanks for the info guys, i am learning ford stuff as i go (was born a chevy guy)
P
project67
116
  • Dec 8, 2009
anybody?
HISSIN50
34
129
Dec 8, 2009
  • Dec 8, 2009
Looks like a t-bird MAF doesn't it? If so, it should not be optimal for the A9* EEC.
No OEM MAF is calibrated for a given injector. The MAF and EEC need to be in synch. The MAF just relates a voltage per volume of air flow. The EEC handles the rest. The calibration aspect comes from aftermarket meters that trick the EEC.
The 93 Cobra had its own MAF.
94-95 cars all use the same MAF (again, the EEC is what handled fuel delivery, whether the car had 19's or 24's).
If you use an A9* EEC with 19's, get a 94-95 Stang MAF. They're cheap and it will outflow the injectors.
Good luck.
P
project67
116
  • Dec 8, 2009
thanks for the reply. i am running 24lb injectors, will the 94-95 maf work? or do i need to go aftermarket? thanks
HISSIN50
34
129
Dec 8, 2009
  • Dec 8, 2009
Unless you have a 93 Cobra EEC, you would need an aftermarket MAF or the ability to tune the EEC or MAF.
P
project67
116
  • Dec 8, 2009
thanks, i will be looking for an aftermarket.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,117
224
Massachusetts
Dec 9, 2009
  • Dec 9, 2009
That's not even the part number for a Cobra MAF. I think it's a 4.6L MAF.
These are the only MAF's known to work with the stock Fox Computer and 19# injectors
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang GT & Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
So you should either go aftermarket, or use one of these MAF's and get a chip burned....the later is actually the prefered method by most
P
project67
116
  • Dec 10, 2009
thanks for the help, i just bought a 75mm pro-m maf calibrated for 24 lb injectors, should be good to go.
vristang
4,933
101
124
Seattle
Dec 10, 2009
  • Dec 10, 2009
f4sf-12b579-aa
afh70-02a
That is a 93 Cobra MAF (or rather it is a meter that superseded the 93 Cobra part number)
Now that you have the right meter though... you could sell that one off...
The previous owner was honest, even if he did build a mismatched car
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,117
224
Massachusetts
Dec 10, 2009
#10
  • Dec 10, 2009
  • #10
The 1993 Cobra MAF p/n is F1SZ-12B579-A
His MAF's p/n is F4SF-12B579-AA which is a 1994-1995 4.6L Thunderbird MAF
Walbro - Mass Air Flow Sensors - Ford
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
