Need help with pilot bearing
  • Thread starter Thread starter stevesLX
  • Start date Start date Jun 15, 2007
stevesLX
373
cincinnati
Jun 15, 2007
  • Jun 15, 2007
O.K. guys I just rented some piece of crap puller from Advance auto parts and it did nothing but make life more complicated it yanked all the needle bearings out of the cage and chewed it up. I stuck my finger in there and there is hardly no lip at all for this pullers jaws to catch on. So now what do I do?
Rick 91GT
Mustang Master
95
99
PA
Jun 15, 2007
  • Jun 15, 2007
Usually those pullers work very well, I used theirs a few times before I went and bought one.
The easiest way now is to use a diegrinder or other small rotary tool and cut the sleeve away, once you get a slit in the sleeve it usually will break and you can pull it out. I hae heard guys using air chisels, put if you slip it could be trouble.
Mr Grim
58
  • Jun 15, 2007
Make sure the fingers on the puller are lined up with the notch in the back of the bearing, then use a wrench to forcefully spread the fingers and keep them engaged while using the slide hammer. It takes a little finess, but it should come out. The key is to make sure the tool is as perpendicular to the bearing face as possible so the fingers are exerting equal force and pulling the bearing straight out.
Good Luck!
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 16, 2007
  • Jun 16, 2007
There should be a considerable lip on the backside of the pilot bearing. The thing has to be about 1 1/2 - 2" wide. The lip where the bearings ride is about 1/8" so you should have plenty of surface to grab onto. My bet is the puller either wasn't completely behind it before you gave it a yank, or the jaws didn't open up enough. Don't sweat yet, just give it another go, those pullers make life a hell of a lot easier than the old way of using grease and a socket
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
M
  • mnky99
  • Sep 5, 2025
mnky99
M
